mopardemon340 Well-Known Member Joined Aug 10, 2015 Messages 553 Reaction score 37 Location WI Feb 23, 2017 #1 need a little help.. how do you plug the heater line input.. we dont have a heater in the car so i need to plug the hole.. its not threaded. Last edited: Feb 23, 2017
dgibby Well-Known Member Joined Aug 23, 2012 Messages 1,093 Reaction score 615 Location Texas Feb 23, 2017 #2 Used a 1/2-13 tap and screwed in the plug
dgibby Well-Known Member Joined Aug 23, 2012 Messages 1,093 Reaction score 615 Location Texas Feb 23, 2017 #3 Or put rubber plug on it with a hose clamp Last edited: Feb 23, 2017
mopardemon340 Well-Known Member Joined Aug 10, 2015 Messages 553 Reaction score 37 Location WI Feb 24, 2017 #4 what size tape is needed so i can tape this and plug it.. i cant find a tap near me to use.. it measures just over 15mm
dgibby Well-Known Member Joined Aug 23, 2012 Messages 1,093 Reaction score 615 Location Texas Feb 24, 2017 #5 Used a 1/2-13 tap and screwed in the plug[/QUOTE]
mopardemon340 Well-Known Member Joined Aug 10, 2015 Messages 553 Reaction score 37 Location WI Feb 24, 2017 #6 1/2 would be to small the hole its self almost 5/8
dgibby Well-Known Member Joined Aug 23, 2012 Messages 1,093 Reaction score 615 Location Texas Feb 24, 2017 #7 its what I used on my small block aluminum pump.
mopardemon340 Well-Known Member Joined Aug 10, 2015 Messages 553 Reaction score 37 Location WI Feb 24, 2017 #8 guess i have to give it a try
mopardemon340 Well-Known Member Joined Aug 10, 2015 Messages 553 Reaction score 37 Location WI Feb 24, 2017 #9 with my kind of water pump it took a 5/8 pipe plug.
dgibby Well-Known Member Joined Aug 23, 2012 Messages 1,093 Reaction score 615 Location Texas Feb 24, 2017 #10 Good deal, glad you got it figured out. Don't forget sealant on the threads.
mopardemon340 Well-Known Member Joined Aug 10, 2015 Messages 553 Reaction score 37 Location WI Feb 24, 2017 #11 machinist took care of all that never even changed me. 3/8 - 18 NPT Last edited: Feb 24, 2017
