Help - what is this bolt
rkjjeep
Pinckney, MI
Big Block 1964 727 - So we went through the whole learn about the park cable/spring etc because it looked like that housing was leaking. It was, but we still had a pretty good drip. After lots of wiping and driving and looking it appeared to be coming out of the bolt with the pen pointed at it in the picture. It is just ABOVE the park lock housing, faces rear, and has a 9/16 hex head. It's at about 1:00 in the picture. I'd like to know the function in case I need to seal it or replace what looks to be a sealing washer.
I didnt catch the pen the first time either. Found it but i am of no help sorry.
Pat Blais says this is a bolt that holds the extension housing to the main body and serves as pivot for park lever. He says it is the only attachment bolt with a sealing washer. Since it serves as a pivot it should not be removed to replace the washer. It was not tight from the trans shop and it was the cause of our leak.
