Help where is the horn relay?
Bobbycz
Active Member
Mesa AZ
The electrical system on the 68 Dodge Dart GT (225 slant six) is giving me fits again. I was stopped and bumped the horn ring by accident and on comes the horn and on and on. You get the drift. I bumped the horn ring a couple of times and it goes out but comes back on. I got home and took the horn ring right off and it still appears to be shorting out.
I looked for the horn relay but was unable to locate. Can someone point me in the right direction?
Thanks
Not quite sure on the 68...but my 72 Darts was mounted to the ashtray bracket....not the ashtray but the piece it slides into...just pull the 3 or 4 screws or look up under the dash and it will be on the driver side of it...if that is where it is...
the relay is on the drivers side just above the kick panel, usually a 5 pin style, kinda looks like a starter relay (In size), but uses spade style terminals.......
