mshred
The Green Manalishi
- Joined
- May 2, 2008
- Messages
- 3,261
- Reaction score
- 150
Hey guys,
Im just about ready to build my 360 roller motor and am at a crossroads for the oiling system. Build is a basic KB107 flattop, closed chamber heads, cam somewhere in the .550" lift range, Street/strip, will see 6800-7000rpm MAX. Plan is to hit somewhere in the high/mid 11's.
Currently have .002" on the mains and rods, main bearings are full groove. Ive gone with a stock volume oil pump (possibly an HP releif spring is nescessary...what do you guys think?). The block will be getting some of the oil mods suggested by Guitar Jones, as well as some other basic mods to the pump and block, nothing too crazy though since its not an endurance motor or anything.
My question is do you guys recommend a stock type pan with windage tray and stock pickup? (and possibly baffled for the pickup) Or should i go to a deep pan i.e. kevko with their 1/2" pickup and crank scraper? What do you guys think will work with the combination im planning in terms of bearing clearances, bearing type, and the stock pump im using
Im open to all opinions here since some say one thing, others say another, so i need to decide for sure
thanks!
thanks!
