akehurst89
Just bout a new pertronix distributor and the rotor isn't pointing at number one on the cap. How do u rotate the rotor to point at number one? Number 4. I have the car on tdc.
Had same issue with a Accel. I just looked at what hole in the distributor the rotor was pointing at, made that the #1.
Just a question... Does it matter which position on the cap you use as number 1? As long as firing order is correct?
A question On the pertronics unit, I read if you replace the points with this unit you have to retime the car, is this true ??
