Hemi 4spd Question
dgc333
Pembroke, MA
Anyone know what the diameter of the sleeve that the throughout bearing slides on?
I am putting a T5 in my Barracuda and the T5 sleeve is larger than the 23 spline 4spd I currently have. Hoping the Hemi 4spd is closer and I can either machine the T5 or the throughout bearing to work.
Did you ever get the info you needed and get this done? Didn't realize you were looking at doing this.
Just curious.
Got the T5, a modified bell housing to bolt it to. Finally found an outfit that sells a box that connects to the speedo sensor on the T5 and will spin the cable to drive the the speedo. The Hemi 4spd throwout bearing will work.
Hasn't been a priority to do but this is the year. Now I just have to get off my butt and get it down.
Sounds like the R154 swap that are I started on my Valiant. Pulled everything when I crushed it, and keep collecting parts to swap it into my Duster, but just haven't progressed.
Glad to hear you still have it in mind, though. Thought I heard you picked up a Focus ST and since you've been awful quiet on the forum for a couple of years I thought maybe you might have just gotten rid of the Barracuda.
