Hemi Help,,, and,, I saw a Robin !
The Cuda
Wis.
Hi, I'm looking for a tool to remove a valve spring off a 426 Hemi without taking off the head. Who makes one that won't break/works ? Thanks.
I've used this on several engines (392 but not tried 426) and it has worked well every time. Got it from OTC but it dose not have a brand stamp anywhere,
I want to thank all of you who responded with the info on removing Hemi valve springs while the head was still on. It's really helped.
May the Gods of the asphalt grant you low E.T.s, High top speeds and a safe return to the pits. Thanks again, The Cuda.
