Hey you guys running superstock springs
EvilScamp
Dalton PA
I just got the mine for my Duster,this is probably gonna be a dumb question but here it is.
I see one spring has a harder arch than the other,is this gonna make my car set on an angle?
Would i have been better of maybe getting 2 left or 2 right side springs?
I'm running stock springs in my Scamp so i never came across this before,any info. would be appreciated. :D
yes it should sit alittle higher on the passenger side. The higher spring rate is on that side to help plant the tires when the car torques over on launch.
Thanks guys,i guess i'll just have to wait until i get them in to see what i need to do to make it sit level.
I was gonna run stock shackles you think maybe i should run adjustable one's?
I would just put them in and run them as is. I can hardly tell that one side of my car sits higher.
When I first put the springs in my car, the passenger side was about 1-1/2 inch higher than the driver's side. Now, a month or so later, it's kind of evened itself out.
Hey Mikel,
How many runs have you made since you installed the springs. I could be out to lunch on this, but maybe they need a few runs to settle to their final resting spot.
Jack
I'm gonna be mounting the battery in the trunk so maybe the extra weight on that side will help level it out quicker.
Hey Mike i never did figure out how to put a pic. in one of those banners for you,sorry i didn't get back to you about it to much stuff going on here lately it slipped my mind.
Maybe someone else on the board can figure it out for you. :)
Coyote Jack said:
Hey Mikel,
Jack
Hmmm... Maybe 10 or 12.
[quote="EvilScampHey Mike i never did figure out how to put a pic. in one of those banners for you,sorry i didn't get back to you about it to much stuff going on here lately it slipped my mind.
Maybe someone else on the board can figure it out for you. :)[/quote]
No big deal. Thanks for trying.
