Slickfish
Slickfish
1966 273ci Commando Complete Rebuilt bored 30 over new Dome Pistons 10:1 compression Falcon Ultimate Cam Shaft Kit Cam Street & Strip 287 dur 480 lift, Double Roller Timing Chain, Melling Hi Volume Oil Pump, Steel Crank , Heads Port Matched to Edelbrock LD4B intake manifold, Engine Block & Crank Shot Peened, Block & Crank Deflashed and Deburred Original dual points distributor, Original exhaust manifolds, 625 CFM Competition Series Carter carburetor, have original 273ci Commando Intake manifold, Machining and short block assembly by Pression Performance Machine Shop in Penticton BC
$6,500 CND = $4,655 USD
Less than 3,000 miles on it !
Locate In Princeton BC V0X 1W0 Canada
Message Me Serious Inquiries Only!
Thanks
Thanks
