Hi-po 273 eahaust from Accurate LTD
toolmanmike
Moderator and forum fixer
Staff member
Office
How many of you have Hi-PO 273 exhaust from Accurate LTD on your early
Darts, Valliants, and Barracudas. Do you have photos? I've never heard the system. Sound bytes would be great! Toolmanmike
I don't have the system from Accurate but have managed to obtain some of the individual pieces (all NOS) for use on my 65 Dart or possibly on my 65 Barracuda that my oldest son will be getting as his inheritance a;though he might want to keep the dual exhaust that's on it now.
Dartman! I'm looking for the pipe that goes over the rearend! Do you have an extra one or know of any NOS ones?
If you are just looking for OEM replacement exhaust, Walker probably makes it. The factory exhaust was marginal at best, hence the Accurate oversized tube diameter. You could always order a drivers side only pipe from TTI.
I bought a complete system from Accurate for my 67 ragtop Barracuda with a 273 engine. Using the stock manifolds, everything bolted up perfectly within an hour. I was amazed how well everything fit! The pipes are bigger than stock and it looks really good. I did not get the hypo setup with the resonator but did get the free flow muffler they offer. It sounds great too! I would highly recommend them for your project because they were very knowledgeable about the application(s) and sent out the complete system right away. All hangars, nuts, bolts, washers etc. came with it; nothing extra needed. (trust me, I don't work for them).
