Hi Po exhaust manifold washers ?
Mopar Exhaust Systems
  1. Daniel Moreno
    Daniel Moreno Dodgedartdan
    105
    13
    Oct 16, 2019
    Milford CT
    Local Time:
    2:18 PM
    52AEAE4F-21FE-4C6A-B0DB-890240CAEB2B.jpeg Xxxxx
    Little help ?
    Which way do I install these cone shaped washers On my hi po exhaust manifolds bolts ?
  2. Alaskan_TA
    Alaskan_TA Well-Known Member
    5,759
    4075
    Nov 12, 2004
    PA
    Local Time:
    2:18 PM
    Pointy end towards the underside of the bolt head.
  3. Daniel Moreno
    105
    13
    Oct 16, 2019
    Milford CT
    Local Time:
    2:18 PM
    Thank you Alaskan !
    Dan M
  4. str12-340
    str12-340 FABO Gold Member FABO Gold Member
    1,477
    865
    Dec 26, 2012
    Vashon, WA
    Local Time:
    11:18 AM
    B !!! The idea is to spread the pressure out on the cast iron ears so you don't crack them off. Seal the end studs so they don't leak antifreeze!!!
  5. Daniel Moreno
    105
    13
    Oct 16, 2019
    Milford CT
    Local Time:
    2:18 PM
  6. Daniel Moreno
    105
    13
    Oct 16, 2019
    Milford CT
    Local Time:
    2:18 PM
    Thanks str12-340.
    Certainly don’t want to break anything.
    Working hard to complete my car.
    FABO is the best.
    • Agree Agree x 1
    • dibbons
      dibbons Well-Known Member
      4,686
      2704
      Nov 6, 2009
      La Paz, B.C.S., Mexico
      Local Time:
      11:18 AM
      The special washers allow exhaust manifolds do expand and contract during the heat cycles without having the fasteners lose their torque setting.
    • Daniel Moreno
      105
      13
      Oct 16, 2019
      Milford CT
      Local Time:
      2:18 PM
      That makes sense. I got these manifolds from that company up in Washington state. Then I bought the hardware and then I bought the exhaust manifold gaskets. I hope they’re worth the money. Thank you !
    • dibbons
      4,686
      2704
      Nov 6, 2009
      Local Time:
      11:18 AM
      The funny thing is, the factory did not install the washers on the two center/middle bolts, only on the two and two on either end. Aftermarket reproduction packages include enough washers for all the fasteners. Some exhaust gaskets have an aluminum/shiny side which also permits the expansion/contraction "slippage".
    • str12-340
      1,477
      865
      Dec 26, 2012
      Vashon, WA
      Local Time:
      11:18 AM
      If you want to make sure this thing seals the first time, I'd recommend Remflex gaskets
    • tonysrt
      tonysrt FABO Gold Member FABO Gold Member
      842
      417
      Dec 25, 2016
      Northport, NY
      Local Time:
      2:18 PM
      I have those repro manifolds from Shaker and painted them with VHT manifold Hi Temp paint and after 2 years still look great. There in a 74 Duster with a 318. Make sure you read directions and follow heat cycle posted on can. I stay away from headers at all costs, because I don't race I just go cruising and like the longevity of cast iron manifolds. I even have repro cast manifolds on my gen2 hemi and after 17 years still look great because I had them Jett coated before installation.
    • pishta
      pishta I know I'm right....
      19,157
      8574
      Oct 13, 2004
      Tustin, CA
      Local Time:
      11:18 AM
      VHT silver will come off on your hand for months if you don't heat treat them as instructed. VHT ceramicoat (?) in white was awesome. Heated it as described (started the motor and let it idle for 30 minutes with a few blips) and that stuff fused to the pipes. 3 years later those pipes were still rust free.
      • Like Like x 1
      • Daniel Moreno
        105
        13
        Oct 16, 2019
        Milford CT
        Local Time:
        2:18 PM
        I bought Mahle gaskets.
        No good ?
      • tonysrt
        842
        417
        Dec 25, 2016
        Northport, NY
        Local Time:
        2:18 PM
        I followed can directions and never had a problem and I used Fel pro gaskets with no leaks. Use what you have for the gaskets, just torque bolts properly because there only 5/16". I used anti rust on the bolts and studs in the head and on the nuts.
      • Daniel Moreno
        105
        13
        Oct 16, 2019
        Milford CT
        Local Time:
        2:18 PM
        What is the torque spec? I plan on using copper anti-rust/seize.
      • tonysrt
        842
        417
        Dec 25, 2016
        Northport, NY
        Local Time:
        2:18 PM
        The bolt is 20 foot pounds and the nut is 15 foot pounds. As you can see not torqued too high.
      • Daniel Moreno
        105
        13
        Oct 16, 2019
        Milford CT
        Local Time:
        2:18 PM
        You the man tonysrt. Thanks bro.
      • Dana67Dart
        Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
        5,597
        3585
        Jul 16, 2017
        Northern Colorado
        Local Time:
        12:18 PM
        Pardon my ignorance...
        I thought, at least in 67, That the exhaust manifolds were the same hp 273 to standard 273?
        In what way are the shaker manifolds different?
      • tonysrt
        842
        417
        Dec 25, 2016
        Northport, NY
        Local Time:
        2:18 PM
        Shaker was the name of the company I bought them from, I believe they also make Shaker parts for the Shaker hoods on E&B body cars. The manifolds are the Hi po 340 from 68-70.
        • Thanks! Thanks! x 1
        • 65Val
          65Val Average Length Member
          5,208
          1158
          Oct 14, 2005
          Victoria, BC, Canada, EH!
          Local Time:
          11:18 AM
          By the way, those aren't just on "HiPo" engines...they're on 2 barrel engines as well as Slant 6's.
          • Agree Agree x 1
          • str12-340
            1,477
            865
            Dec 26, 2012
            Vashon, WA
            Local Time:
            11:18 AM
          • RustyRatRod
            RustyRatRod Lemmie see your b00bs. FABO Gold Member
            67,785
            42095
            Jun 7, 2010
            Georgia
            Local Time:
            2:18 PM
            Look at the washer. Think of it as a spring, because believe it or not, it is. B
            • Like Like x 1
            • chrgdrt
              chrgdrt Well-Known Member
              297
              118
              Nov 1, 2009
              Richmond, Mi
              Local Time:
              2:18 PM
              I think he's referring to the washers
              • Agree Agree x 1
              • toolmanmike
                toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                55,989
                42284
                Jan 18, 2006
                Iowa
                Local Time:
                1:18 PM
                They were and the same manifold for the 318's unless they needed changed for a different application.
