I want to start with higher octane and work my way back to see what will be sufficient in my new stroker about 10.5 to 1 CR. I have 93 octane here at the pump. Any place in N IL to get some higher to mix in?
I was hoping I could do that too, just wanted to be cautious from the 1st start and work my way back. Thanks for the info.Just my .02..my 416 with 11.9 to 1 compression ran just fine on 93 octane:thumleft::thumleft:
Is that with aluminum or iron heads?
My car also has about that same compression (x-heads). With super I can drive around just fine but I don't hammer on it.
My problem is the car is so loud I don't think I could hear if it was detonating.
The airoprt near me sells 100 for $4.75/ gallon but he said it is low lead fuel. is the low lead a problem?Some of your small airports sell 100 leaded for about 4.50 a gallon.
If you have hardened valves/seats then low lead is not a problem. You can mix the two 93 and 100 and get 96.5(approx)
On another note.
Don't want to start an arguement over this but I have heard/read that 10.5 CR (iron) and 11.5 CR (aluminum) is the max "SAFE" CR to use 93 octane. It may run fine on the street but not the best to do if you hammer it, you could have issues. Better safe than sorry.
