El Guapo 604
Member
Chronic cooling issues with my 440 has forced me to look at different cooling options and I'm in need of advice.
I'm currently running an aluminum 2 core rad with an electric puller fan which is not suitable for cruising...not good at all, really. Running too hot all the time...around 210. Getting tired of stressing out with one eye always on the temp gauge. I'm getting squealing on hot startups sometimes so I'm assuming the water pump is on it's way out, so I'm considering going with a high volume impeller when I replace it. I see mixed opinions everywhere on the web but I really can't see it hurting at all. Anyone have any experience/opinions with high flow impeller on a hot 440?
(I'm not expecting this to solve my heat issues-just thought the HV unit would be a good way to eliminate flow questions on the way to a solution.)
