Hight rise intake throttle cable mod
Snake
Mopar Nut
Belleville Canada
If you have high rise intake with a spacer you factory throttle cable bracket is going to cause you grief,I had a sticking cable,very stiff cable.So I did this mod very easy and cheep.i just bent a peirce of steel to the right height bolt to my bracket then cut off the peirce off an old bracket the clamps down the throttle cable,then bolt it to peirce i made.done,very cheap and easy to do,just have a few tweaks than pull it apart and paint. Finely something that went my way.
