[FOR SALE] Hobart Spool gun DP-3035-10
340swinger4spd
Beldenville WI
I have a Hobart Spool gun DP-3035-10 for sale. I bought the wrong gun so it wouldn't hook up correctly to my welder. This is also compatible with some miller units. $185 OBO
Which welder do you have? I can't find interchange info on it.
Can you take a picture of the leads and how many holes in the twist lock plug?
I dont recognize the set up for a Miller as they are a 14 pin amphenol style plug for a direct fit connection.
A direct fit for Miller into a 210 is typically a 4 wire plug.
I'm thinking only a Hobart Machine will work. The more details the easier it is to sell ( or buy).
Good luck.
Good luck.
I have added a couple more pics. It is a 4 pin plug which worked on my MM210. Like I said before the positive lug is to small to hook up normally.
