Backally FABO Gold Member FABO Gold Member Joined Sep 4, 2011 Messages 631 Reaction score 401 Location Wisconsin Jan 8, 2013 #1 Was under my Duster, 70 with 340 and noticed a hole in the block right by the starter. Never noticed this before. It's about an inch around not sure how deep. What is it, and it is supposed to be open like this? Attachments engine bottom pointer.jpg 69.5 KB · Views: 282
deviledchin FABO Gold Member FABO Gold Member Joined Mar 15, 2012 Messages 521 Reaction score 182 Location Sellersville,Pa Jan 8, 2013 #2 Curious to see where this goes because I have a 71 4spd with a square head bolt or similar casted or welded in crooked.
66340SEDAN FABO Member #3649 Joined Nov 20, 2006 Messages 25,990 Reaction score 35,589 Location Minnesota Jan 8, 2013 #3 Must have something to do with how the block is made in the tooling process or something, nothing goes though it and its not threaded
B Bulldozer free ice cream sandwiches Joined Oct 16, 2011 Messages 14,985 Reaction score 2,404 Location behind the wheel Jan 8, 2013 #4 i think that was casted into the block as a means of picking them up during the casting/assembly process
rob_robinson87 Well-Known Member Joined Oct 8, 2008 Messages 594 Reaction score 22 Location Newport, NC Jan 8, 2013 #5 Yep. Discussed here also. http://www.forabodiesonly.com/mopar/showthread.php?t=140778
deviledchin FABO Gold Member FABO Gold Member Joined Mar 15, 2012 Messages 521 Reaction score 182 Location Sellersville,Pa Jan 8, 2013 #6 I thought something blew apart till I got the trans out. Then I started breathing again...
younggun2.0 Well-Known Member Joined Jan 27, 2012 Messages 4,793 Reaction score 1,520 Location federal way, wa Jan 8, 2013 #7 looks like the "border mule" optioned block. you can hide all kinds of stuff you dont want found in there.
Backally FABO Gold Member FABO Gold Member Joined Sep 4, 2011 Messages 631 Reaction score 401 Location Wisconsin Jan 8, 2013 #8 Thanks, sounds like nothing to worry about.
william Well-Known Member Joined Aug 13, 2009 Messages 179 Reaction score 32 Location Ottawa Jan 8, 2013 #9 Nope nothing to worry about my 93 ram has the same hole but it has a plastic plug in it.
Oldmanmopar Going left turning right FABO Gold Member Joined Jan 8, 2009 Messages 14,224 Reaction score 14,782 Location Danielsville Pa. 18038 Jan 8, 2013 #10 Look close Attachments 44416[2].jpg 80.8 KB · Views: 193 DSCF0011[1].jpg 90.6 KB · Views: 192 DSCF0004[1].jpg 109.4 KB · Views: 196 DSCF0005[1].jpg 101.4 KB · Views: 186 b43[1].jpg 93.6 KB · Views: 200 b30[1].jpg 101.1 KB · Views: 199
Oldmanmopar Going left turning right FABO Gold Member Joined Jan 8, 2009 Messages 14,224 Reaction score 14,782 Location Danielsville Pa. 18038 Jan 9, 2013 #11 Used on assembly
doug 371 Well-Known Member Joined May 29, 2004 Messages 3,030 Reaction score 1,555 Location Regina, SK CANADA Jan 9, 2013 #12 very nice
Oldmanmopar Going left turning right FABO Gold Member Joined Jan 8, 2009 Messages 14,224 Reaction score 14,782 Location Danielsville Pa. 18038 Jan 9, 2013 #13 The extra cross tubes are to pick it up with a fork lift to get it to the second floor
