[Found!] Holley 390 CFM
cchrishefish
USA
I am looking for a Holley 390 4 barrel. I would prefer an electric choke, but I know that a choke kit can be purchased from Holley.
Package: 4 Barrel Set-Up General Multi-Purpose
Carburetor: Holley List 6299
Manifold: Offenhauser Aluminum 4 Barrel PN P3690801
Manifold Modifications: None
Carb Specifications: 390 cfm Holley, vacuum secondaries
Primary Jet: #49
Secondary Jet: #52
Power Valve: 25R-591A-65
PV Channel Restriction: .052
Idle Air Bleed: .078
High Speed Bleed: .043
Diaphragm Spring: Yellow
Primary Jet: #49
Secondary Jet: #52
I found the specs from slantsix.org, I may decide to custom order one.
Primary Jet: #49
Secondary Jet: #52
I have a Holley 8007 with electric choke, dusty from sitting but never had gas through it.
