Holley 4777. 650 double pumper
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
Little use, friend went to Injection years ago
Holley Brand kit installed
Dusty, small cobweb in venturi
Front bowl vent damaged slighty
"Slightly discolored" in places
Manual choke
stock jetting and power valve
line net included
Whats it worth ?
30 day warranty
150-200 bucks maybe
Straight boosters, manual choke, 2 corner idle.
On a well built 340 they're about 20+ ft lbs of torque down from a 750 dbl pumper above 4500 rpm. They are great for a 318.
I think you'd have been better off including the rebuild kit parts separately. As a buyer, I prefer to rebuild it myself than trust the word of a seller of a used carb.
Used carbs are a gamble period...but I dont have any issue with the seller rebuilding it himself. The gaskets are reusable and you can take the 2 bowls off when you change power valves anyways..and inspect it all n set floats. There isnt much to a carburetor... throttle base plate, 2 meter blocks, 2 bowls, a shooter, jets, pv, accelerator pump...check ball or valve..etc.
I get into a carburetor three or four times to tune before I leave it alone.lol
Id take that over anything new for the same cfm and should be a good carb when set up correctly. Maybe send it out and get it recoed so it looks prettier.
