Hey guys you ever changed jets on a carb to richin it and nothing hardly changed? My carbs factory jets had 71 80. Now overtime they are at 78 87. I'm thinkin could my acc. Pump be too small or the squirters too small?
I have a 4779 in the parts tank now. Factory 73 jets in it, power valve in the primary side only. I am jetting it up to 75 and 85. I am not liking having just the power valve on one side so will probably sell it or trade for a different model. You have to understand that just because you are giving the car more fuel, it doesn't necessarily mean your motor is able to handle it. Timing, compression, spark plugs, ignition, etc ... have very large roles to play in burning all that extra fuel and putting it's power to the wheels. Just dumping more fuel doesn't automatically mean more power.
Let me take a crack at it. You keep jetting it up because you get a surge at light throttle cruise, but adding jet doesn't do anything. Would the rpm's happen to be in the 1800-2200 range when it happens? And when leaving a red light, just lightly pulling away, it stumbles, but if you give it some gas it'll jump and get going. While cruising it's not so much as problem, but only when trying to accelerate from ~ idle speeds. Am I close to describing the issues?
