[SOLD] Holley 4bbl carb
Nite Moves
Belleville,ontario,canada
I have a holley 4bbl carb. Not sure of size/model. Its in need of cleaning and kit for sure. Asking $45 plus shipping. Hopefully its worth something to someone.
It's a 4160 type due to the lack of secondary metering block (4160 uses a non adjustable plate instead). You can make a reasonable size (factory CFM) guess if you measure the throttle blade diameters although the venturi size that ultimately determines flow through the throttle blades.
Rough guess; it probably started life as a 3310-2 750 CFM before someone cut the choke horn off.
Its not the price, Its the shipping from Canada. I would have bought your 2bbl too. It is what it is. Glad you got it sold.
