Holley fuel bowl thread tap
arnie_human
Active Member
Holland
Hello guys
I'm repairing a holley carb at the moment and one of the long fuel bowl bolts has broken off. Can someone tell me which thread tap I need to get a new bolt in? I allready got a UNC 1/4 tap bit thats to big. Here in Holland we only measure in metric. So bit of a hassle to find correct thread tap.
Thanks guys.
Gr Arnoud
You will need a repair kit for 12-24, Heli-coil tap and Heli-coil. It might be tight if you already tapped it 14-20?
I have worked on old British bikes, 50's Triumphs that have BS British standard, BSW British standard Whitworth, BSPP British Standard Pipe Parallel, BSPT British Standard Pipe Tapered What a nightmare, and metric has 3 thread pitches, English has fine & coarse. Then there is trying to teach a newbe about threads, they just look at me like I'm crazy.
Yes 12-24 sounds right. There's a full list of threads used on Holleys somewhere on RFS. I'll add a link in bit.
There's a few other companies now making quality thread repair inserts (besides Helicoil). I think one is out of Australia. In any event, your closest source of Unified thread stuff is probably the UK.
Deep Roots Holley Thread Sizes and Torque Notes
Yep...all those threads make you say swear words. Lots of them.
how big a hurry are you in Arnie?
i'll be heading that way in July and if you want to, i can bring a kit then
but im sure places like Stadegaard, or Hendriks would carry them, or could order one for you
in fact, als ik jou was zou ik Hendriks gewoon even bellen, 0413 338100
