Demon540
Small block. Holley strip dominator. Part # is 701-R-8. It has a small crack where a plug was installed too tight. It doesn't not go inside the port see pic. Red arrow.Has not been ported or cut. 2 plugs welded shut by the themostat housing. ( Not needed). All the bolt holes r good. Exempt one May need a helicoil. Which is the far back left carb stud. It Has half the threads on that hole r bad. A stud would still work. It was painted black. $100 plus shipping from 54703.
