74Dusted
Stock Piler of 340's
Any of you have a little bit of experience with home audio (surround sound) systems?
I've been thinking about wiring my Half-Stack (guitar amp) into my Surround Sound system, to really rattle some windows. Is it as simple as connecting the Outputs on my half stack to the inputs on the surround sound? Or do I need additional equipment? I'd try it and see, but I'd rather know ahead of time (in case it could let the smoke out of something). I'm not too worried about the Surround Sound, it's an old Sony STR-AV570 unit that was free, but my Peavey Half Stack is another story, those aren't exactly cheap.
I currently have my Computers, TV, Record Player, Minidisc Recorder, Tuner, Cassette Deck, 8-Track Deck, and CD Changer wired into the Surround Sound with no problem. And for being a free (ancient) Sony Surround Sound Head Unit, it will rattle stuff off the walls, with the volume set almost as low as it will go (hence the reason I want to wire in the guitar amp )
I still need to add a Subwoofer to the surround sound setup, and wire in some speakers for some other rooms. (probably going to need an external amp to add additional rooms to the setup?) Currently I only have 10 speakers, in the living room only. But I can hear it anywhere in the house (and the garage), with the volume set to 1 I'm glad my closest neighbor lives a good distance away
