If you think stripper is a mess, you have never sandblasted. It gets everywhere and falls out of the car after that. I blasted the underside, interior and engine bay of my Demon about 1 1/2 years ago. It is still falling out of the body and that is after blowing it out with compressed air for and entire afternoon.
That being said, would I do it again? You bet, you know what you have after that.
I'm not sure what Harbour Freight sells, but don't get a siphon feed blaster. They use way to much air and you can't keep the air pressure up if you are using a 25 gallon or less compressor.
Be carefull how long you hold the blasting sand in one spot. It can warp the metal.
Hope this helps
Jack
