Homemade 2bbl Linkage Bracket Solutions
zmarty27
Texas
I figured a helpful thread to many would be a thread dedicated to photos of homemade linkage brackets for 2bbl conversions. Naturally, these brackets are in limited supply and high demand. I've seen some creative solutions to this problem, many of which are on here and vaguely mentioned, but mixed into the vast library of threads. If you have some pics of what you've done, post it below if you'd like. I'm personally about to pull the trigger on a piece of angle iron, and fashion some kind of clamp to it for an after market cable setup. Best of luck, and thanks for the read!
It’s been 20+ years since I did it, but I was able to make the 1bbl linkage from my 70 Dart work without fabrication. I’ll see if I can find a picture.
