gregpurcell
Greg Purcell
This is a power steering column from a 67 Dart that someone converted from a column shift to a floor shift. I have seen articles on how to do it but never owned one before. I THINK that they did bodywork on the collar with JB weld or something but they could have swapped out the collar itself. It looks pretty good and is really hard to tell.
Obviously this is not going to work on a 100 point show car, but if you converted your column shift to a console shift or a 4 speed, this would be a good way to avoid the (150-$300) cost of a real floor shift column.
It needs a quick sand down and repaint but otherwise should be ready to go! The turn signal switch handle is included (it was removed for shipping) The threads that hold down the wheel are good, the lower linkage lever was cut off to make it look more realistic. One wire was cut in the harness but I think that was to the light on the PRNDL plate which was removed.
Located in Savannah, GA the price is $75 plus shipping or I can deliver to the Mopar Nats If paid in advance.
Thanks for looking!
NOTE: If you need one or want to do it yourself I also have a 68 column shift power steering column that has NOT been modified. $50 plus shipping PM for pics.
Thanks for looking!
