Found this.
Has pictures also.
Dayton, Ohio--- Craigslist
transaction protection/certification/guarantee. More info
2 cb 750 choppers - $1 (huber/ piqua)
Reply to:
[email protected] [Errors when replying to ads?]
Date: 2009-06-27, 6:02PM EDT
I have 2 Honda cb 750's with titles. The first 1 is a Santee frame with springer front end with the chrome in nice shape, invader wheels that are showing age. It is rideable but I would not go far, I have receipts for about $600 dollars of work on it. THE CARBS NEED SOME ADJUSTMENT OR REPAIR. I had them worked on and it started dumping tons of fuel in the oil, took an old set I had swapped needle valves and slowed the fuel down greatly, however not as smooth now and drained oil and stripped drain plug and cracked pan so now it has an oil leak, ebay pans run 10 to 15 bucks. $2200 or best offer. The second one without the seat is a bolt in santee frame piece, Harley rear tire, frame just painted a silver color looks nice needs assembled, 2 boxes of parts as well to help on the assembly time, will need wired as well both bikes supposedly have an 810 kit in them but I have no proof. If either one has a kit it would be the silver one the engines gaskets look knew and it sounds healthy but now I can not start it once I converted the frame$1000 or offer for that one and its in Piqua. Or I will make a great deal on both of them for $2500 very firm!!!!! Might trade for nice pop up, small pull behind trailer, extended cab truck in nice shape, fox body mustang or ? absolutely no bull or low ballers, tire kickers you know who you are cash in hand local buyers only! DO NOT WASTE MY TIME OR YOURS WITH STUPIDITY MY TIME IS PRECIOUS TO ME AND HOPEFULLY YOU! Thanks
it's NOT ok to contact this poster with services or other commercial interests
PostingID: 1242896969
