Hood clearance question
lotharamc
Member
Cincinnati
75 Dart to recieve a 5.9 magnum.
Do I need to worry about hood clearance if I go with the eddy air gap? Probably a eddy carb as well.
@GTX JOHN is probably right. I have a 69 Barracuda with a 340. I put an Air Gap and a 750 CFM Eddy carb on it. My clearance was close, so I went with a 2" or 2.5" tall (I really don't remember) K&N filter. The guy at K&N told me that it would outflow the 3" paper element. Everything worked fine. The hood did close OK before, but it was very close. The new filter element gave me extra space and extra peace of mind.
You can get it to work pretty easy. Might want a dropped base to give you a bit more room. It also changes the throttle cable/kick down setup. There is an aftermarket taller bracket.
