Hood Clearence
Sterling
Pottstown,Pa.
I am building a 372 engine for a 69 Dodge Dart. 340 block, Scat rotating assembly, Trick Flow heads , and the customer just got a Edelbrock RPM Air Gap manifold. The Dart has the stock 340 hood on it, and a RMS Front Suspension. The Air Gap manifold is 1" taller than his old intake, will there be enough clearence for a air cleaner ?
I ran into a similar problem. Magnum engine, RMS Alterkation suspension. I am using a factory style unsilenced air cleaner with a Mancini Racing supplied air cleaner base. Works great!
Here's a Pic.
Cheers!
  • 1-800-843-2821
CUSTOMER SUPPORT
  • Mancini Racing "Low Pro" 13" Air Cleaner Baseplate
Item #: MRE28160
Price: $33.99
Mancini Racing "High Lip" Air Cleaner Baseplate
$33.99
Mancini Racing Air Cleaner Baseplate
$15.95
I didnt know about the mancini piece and found that a ford 13" base is the same dropped situation. I think I got that hack off of this fine establishment.
