straightlinespeed
Sometimes I pretend to be normal
So I went to replace the hood hinges and realized that it had push on washers or what ever you call them. I measured the stud the hinges are mounted to and I came up with 1/2". If I purchase just half inch washers from a place like Ace hardware will those work correctly? Or is it a special washer that I should be looking for?
