[Found!] Hood Hinges for 72 Dart
Heywodja
The Heartbeat Stops Here
Texas
Looking for a solid set of hinges and fasteners for the hood and hinges.
I need a set that are ready for paint and install for my 72 Dart.
I have a good set from a 73 Duster. I'm sure I have the correct factory bolts also, just not sure of the size. The hinges are clean but need to be readied for painting.
$110 shipped to you for the pair. I thought I had pics. but I will send some if interested.
If it’s not a hassle please send a couple of photos.
I just got home & took photos for you.
My hinges have some some different slots on them where the hood attaches… do you think yours will work?
Look at your hood. Factory set up was If the mounting holes are on an adjustment slider, you want the single hole hinges. If the mounts are solid, you want slotted hinges for adjustment.
IIRC, you can use the slotted/slider together.
I believe 70-71 had the single hole, 72 was the slotted.
Mine are horizontal slotted not sure if those hinges will work or not.
Thanks
The hinges should fit OK but, you having the vertical slotted hinges may not give you the same adjustment needed for your hood. I thought they went to the horizontal slot like mine in 72. I'm sure someone here has the correct hinges you need. Sorry I could be of help.
No worries, I was not aware of the whole horizontal / vertical deal
