Hood Pins on a '67 Barracuda
I have mine located approx. 9" in from each edge of the fender on the radiator support bracket. you could go less so it would be closer to the edges, if you preferred. I have a lift off hood, but used the same pins when I had a glass hinged hood.
Thanks Rick!
Would you have a pic with the hood open?
Hope this helps. Pete
here are a couple pics...the foam in the center is my prop rod that was used when it was a hinged hood....
I dont have any pictures but I removed the fender bolt and put the pin there,
