Hooker fenderwell header templates
Riff Raff
Central Ny
I know I've seen these posted several times but can't locate them in the search. Need the templates for cutting the inner fenderwell.
Thanks Jeff
Thanks Jeff
In my 66 Valiant sedan, this should give you an idea,
I dont have a template anymore, but unless it's going to be a drag only car, I'd just trim small areas and open it as needed.
I used the templates on my '75 Dart Sport and it takes away a lot more than what's necessary. On my '65 Barracuda I chose to cut only what was necessary and it makes it look a lot cleaner under the hood.
I know these are semi-fenderwell headers in the links, but you get the idea.
65 Barracuda w/500ci 440, Stage VI Max Wedge Port Heads, 4-speed, and 4.10 Dana
This is what I did on my 72 dart, just cut out the minimum required, and cut nice round corners, not 90 degree corners.
I'm assuming that your car in an A body. Here's shots of my Demon.
I hope that these help.
Ted
