73ScampSS
Active Member
Anyone using this setup?? The Hooker Headers with the Offenhauser 4bbl intake.. they put a bung on one of the header tubes to run heat up to the bottom of the stock intake. The Offenhauser intake is much farther away and I'm wondering what kind of pipe or tube did you use to run heat to the bottom of the intake.. Thanks
:sign3:
:sign3:
