Hooker Headers- Passenger Side
AUYankee05
Member
Georgia
Need some help!
I have a 1972 340 Duster that I have a set of Hooker headers for...Driver side fits (tight) but the passenger side is hitting the torsion bar. The car ride height needs to get adjusted as I just got it out of the paint shop.
Any advice? I want to adjust the ride height to see if' I can get enough clearance to get the header in place. It is sitting off of the head ~1/4" at the bottom so I am real close.
Thanks for the help!
I have used a big hose clamp to pull a tube away from things and then a nice tack weld to another tube to keep it there.
Just a possibility if it'll help you guys.
At first I was worried it might pull a spot out of one of the tubes, but it seems the heat cycling relaxed the tube so it stayed with out pulling a hole in one.
