%$#&* Hooker Headers!
Mopar Exhaust Systems
  1. 71Duster
    71Duster Well-Known Member
    966
    9
    May 22, 2004
    Alberta Canada
    Local Time:
    6:08 AM
    I pulled the heads of this winter, I knew the leaked abit before but nothing to serious, bought the new fel-pro raceing header gaskets and they leak like a sive! Tightened and re-tighened the bolts but b oth sides leak bad. I didnt like the way the flanges where made on them with the raised sealing edge. Are there any gaskets I can use untill I have the cash to buy some TTI's?
  2. sweatybetty
    sweatybetty Well-Known Member
    1,022
    2
    May 24, 2004
    Local Time:
    5:08 AM
    try doubling up the gaskets. has worked for me
  3. moper
    moper FABO Gold Member FABO Gold Member
    15,759
    1880
    Dec 27, 2004
    eastern CT
    Local Time:
    12:08 PM
    In most cases, the flanges are warped due to us overtightening, so they dont leak..I always use the Mr Gakset Ultraseals, and I use flat file to remove any high spots..Do not use any silicone on the mating surfaces, only on the threads of the bolts, and tighten for the center two out. I also will replce the supplied bolts with either allen headed, or std cap screw styles that are about 1/4 inch longer, so they dont weep coolant. if you really tighten them so they dont leak, you bend the outer flanges every time. the stage 8 locking bolts are the ticket with aluminum heads..
  4. snowymountainman
    snowymountainman Hair in the breeze
    93
    1
    Dec 9, 2004
    Wyoming
    Local Time:
    6:08 AM
    A goos set of HP manifolds will cure all that ails you. Sounds so nice when the exhaust doesn't leak.
  5. 71Duster
    966
    9
    May 22, 2004
    Alberta Canada
    Local Time:
    6:08 AM
    With my cam and set up I need The heades, and the 68-69 HP manifolds are getting pricey these days. I was talking to Don@FBO today and he has hooker supercomps on his Fish Fry and sold me a set of Cometic header gaskets. Gonna see how they go.
  6. superdart
    superdart A little misguided...
    1,139
    5
    Aug 26, 2004
    Arlington, Texas
    Local Time:
    7:08 AM
    I hear the cometics are THE way to go.
