Horn ring removal?
Duster71
Active Member
Anybody know how to remove the horn ring from a 3 spoke half ring steering wheel for a 69 Dart?
I don't know specifically, but if it does not use screws you push in and turn to the left like removing a tail light bulb.
I'll try that, this one is the one with the big rubber pad covering the three spokes, might be a little hard to turn like you described. Thank you.
