JGC403
Whats the horsepower limit of the stock LA/ Magnum blocks? I have read in the 500 horsepower range. Is this correct?
I've seen dyno'd 670's, but it is also the ting of how long do you want it to live? And in what conditions?
The answer is relative to how much CFM airflow you can get the engine to injest and expel....not the brute strength of the metal holding it together.
Your question is excessively vague to answer precisely.
I have seen 150hp 318's to 500hp 360's.
The differences on the engines were simple part changes, and machine work...nothing drastic.
Small Blocks actual metal strength can hold together over 1000hp no problem......actually getting that much AIR and FUEL through one is a different story. :love6:
Good Luck.
