68dodge
I went to install the Hotchkis 1 1/2" sway bar on my 65 Dart. Turns out, the front bracket will not work on the K-frame. The mounts would be to far forward. Had to the cut the brackets, add some metal and installed them vertical instead of horizonal like in the direction. Took the 65 for a ride, what a difference it made on the handling. Also installed a set of Edlebrock gas shocks. They also made the handling much better.
