VIOLENT\6
12 second N/A Slant 6?
Okay, I have decided to forgo the de-stroked 360 idea & just go W/a streetable 10.5:1 360 for my sons "65" Valiant.
This is to be a moderate budget streetable daily driver to run on 93 octane pump gas. It will see ocasional strip use & I want it to terrorize The new Mustang GTs. I want to keep the engine work within $5000.
The car will be a sleeper & will maintain a stock appearance similar to this.
Here is the combo I have in mind. Let's say it would be coupled W/ about a 2500 RPM stall, Torqueflite W/3.91 axle ratio 8 3/4" diff.
I would start out W/a 360 LA block/rods/crank. Line bore the mains, square up the deck & take it to 0.00" W/the KB pistons. Recondition the rods W/ARP rod bolts & free floating wrist pins. The bore & crank would be cleaned up to OEM clearances.
What would be a good flat tappet cam for this set up? I am thinking Comp 480H. Can I run 1.6 rockers on the LA? I want to twist 6200 RPM out of it W/mid range torque & drivability being foremost.
Would this combo make a drivable 450 HP @ the crank?
Opinions please?
- Edelbrock Performer RPM heads, 63cc chambers/171cc int runners/77cc ex runners 2.02/1.60 valves
- Summit Street/Strip Phase III Dual plane Intake manifold. (similar to Edelbrock Performer RPM Air Gap)
- KB 107040 Hypereutectic flat top pistons @ 0.00" deck, .0015" clearance.
- .050 " copper head gasket
- Edelbrock "Thunder" 800 CFM AVS carb.
- Dougs Full length ceramic coated headers.
Opinions please?
