How "Anal" Are You With Respect to Runs in Paint?
Mopar Body and Trim
  1. R4Sedan
    R4Sedan Larry FABO Gold Member
    5,041
    2376
    Nov 26, 2009
    Weeki Wachee, Fl
    Local Time:
    3:03 AM
    Looks, Nice. Real Nice. Clarke. lol
  2. barbee6043
    barbee6043 barbee 6043 FABO Gold Member
    12,890
    5483
    Jul 20, 2008
    Shepherd, Texas ( SE Tx)
    Local Time:
    2:03 AM
    Two coats of RustOleum tractor enamel to fill the pits, then topcoat.
    Or: Epoxy primer, filler, sand, epoxy primer, high build urethane primer, sand, topcoat. If 2 stage, wet sand and buff.
    There is anal and and then there is anal?? lol
    • Agree Agree x 1
    • sabre67
      sabre67 FABO Gold Member FABO Gold Member
      956
      224
      Jan 9, 2015
      British Columbia,Canada
      Local Time:
      12:03 AM
      Who would have thought a run in a oil pan would get over 28 responses go figure:lol: If anyone asks tell them thats a factory run.
    • cudamark
      cudamark FABO Gold Member FABO Gold Member
      7,267
      490
      Mar 14, 2009
      San Diego
      Local Time:
      12:03 AM
      It's not the factory correct pan for your '65 anyway.........:drama:
      • Like Like x 1
      • cudascott
        cudascott Now I have a Hemi
        1,766
        623
        Jan 11, 2012
        TN
        Local Time:
        3:03 AM
        When the rest of it has rust the part under the run will be clean metal.
      • Ottmundr
        Ottmundr 68 Fastback
        6,386
        9495
        Oct 5, 2012
        Sonoma
        Local Time:
        12:03 AM
        Going back to my dusty old memories of the huge waste of time that junior college was...
        This used to be a technical term, much like mentally retarded. It comes from psychology, Sigmund Freud used it as a descriptive term for infants who were fastidious, and didn't play with their poop. As opposed to the mentally retarded individuals who played with their own poop, referred to as anal expulsive.
        The story from the professor was that some infants/children got caught "playing in the mud," so to speak, got such a thrashing that they learned to retain their shit...
      • Kern Dog
        Kern Dog FABO Gold Member FABO Gold Member
        4,686
        6734
        May 23, 2010
        Granite bay CA
        Local Time:
        12:03 AM
        Uhhh....
        I read any reference to ANAL and instantly see it as a literal reference.
        I'm that way with a LOT of language though. My default thought is to take each word in literal terms.
        I don't like hearing "How are you"? unless the person asking really means it.
        I don't like when people say....."The speed limit sign said 55". Signs don't say anything. They cannot speak.
        Take a piss.
        Held my breath for an hour.
        She must have dated a hundred guys.
        The car made 500 horsepower.
        I'm starving.
        NONE of the above are factually correct when most people say them but we accept them as being a figurative description, not literal.
        I find that stuff funny.
      • Princess Valiant
        Princess Valiant Duster specialist FABO Gold Member
        22,760
        14937
        Dec 14, 2011
        Colorado
        Local Time:
        1:03 AM
        I'd sand and repaint, that would bug me and I wouldn't let it slide. Just because you can't see something doesn't mean it isn't there.
        I have done "body work" on oil pans before because they shouldn't have any dents and then painted them with the same process you would paint the car with.
        I always primer engine parts, never just spray engine paint straight on because the color will fade faster than over primer.
        I'd absolutely re do that pan
        • Like Like x 1
        • cawley
          cawley 383 Bcuda
          2,113
          433
          Sep 10, 2013
          milton
          Local Time:
          3:03 AM
          who is going to see it ? if they bend down to look run them over lol
          • Like Like x 2
          • Agree Agree x 1
          • harrisonm
            harrisonm Well-Known Member
            2,818
            2735
            Jan 16, 2005
            Topeka, KS
            Local Time:
            7:03 AM
            Well, It either bugs you enough to fix it, or it doesn't. I think it does bother you a bit, or you would not have started this thread. Here is my thought. I am totally anal with paint runs. I would fix that run. Even if nobody would ever see it, I would know it was there. It will take very little time to sand the run, scuff the entire pan, and respray it. I do a LOT of painting, so here are a few questions for you. The pan looked pretty rough. How did you prep it. If all you did was sand it a bit and spray paint on it, the chances of a good, long lasting result is pretty low. The rust needs to be treated with something. There are lots of treatments that will kill rust and/or convert it into a hard, black substance. Next question is what kind of paint did you use? Some are better than others. Rattle can or spray gun? Properly applied, Dupli Color engine paint works very well. Did you use any primer? As rough as that oil pan looked, you should have. Unless the paint can says that DTM (direct to metal) application is OK, I would use primer. Actually, I would use primer anyway, but if you don't want to use primer and are VERY careful and make your first few coats light and observe an appropriate flash time, those first few coats can serve as a primer. How heavy were the coats. Remember that the first coat is ALWAYS a light coat called a tack coat. never go for coverage with the first coat. One very light coat, followed by a medium coat, followed by a medium wet coat, followed by a wet coat is the way to go. Observe manufacturers suggested flash times; giving a bit more flash time before the final wet coat. go for about 50% overlap and move fast enough to help avoid the runs. After a few passes, you will find a speed that will work.
          • Kern Dog
            4,686
            6734
            May 23, 2010
            Granite bay CA
            Local Time:
            12:03 AM
            Some of you guys REALLY like the ass.
          • dibbons
            dibbons FABO Gold Member FABO Gold Member
            4,401
            2531
            Nov 6, 2009
            La Paz, B.C.S., Mexico
            Local Time:
            12:03 AM
            For the curious, my oil pan prep included detergent washing, wire brush/drill, wax and grease remover, Ospho coat, RustOleum rust convertor, Duplicolor engine paint, Duplicolor engine clear coat. I forget now, maybe a session of Naval Jelly in there, too.
            • Like Like x 1
