Evaporust s kinda expensive for dipping trans parts unless they are small. Works great though. I think I spent 12 bucks on a 16 oz bottle. Keep it covered so it doesn't evapo-rate.
You are going to dissemble the trans before the evaporust dip, not just dip the whole trans?
okay this is a thought it is water base could you paint it on a larger parts and rise it of with a hose? or go to tractor supply and get a wash tub and fill that dip the parts then when put it back in the container that purchased it in?
Put it in plastic rubber maid containers with a lid.
