To DIRECTLY answer the question you asked, since you never said it was actually in a vehicle, there is a casting number on the driver side of the block behind the manifolds, but they are the same for a 198 and 225. There is a pad on the block rail just under the valve cover lip on the passenger side that should have the displacement stamped into it. Probably a lot of grease on it.
