piperdrums
I have a 65 barracuda and I need help adjusting the timing.
Thanks
Thanks
Unplug vacuum advance hose from distributor. Timing light and you should get (or should be) around 16-18 degrees. If not, there is a bolt that goes thru a clamp to hold the distributor in place and you need to be able to rotate the distributor by hand until you achieve 16-18
Whoah...
Let's not forget that initial timing will change total timing and even more so with a vacum advance distributer. There si nothing wrong with that initial timing but ALWAYS check total.
My advice is to plug off that vacuum advance and just run mechanical advance. Wither way CHECK THE TOTAL
Whoah...
Before you make an adjustment, put your hand on the valve cover and get a feel for the engine vibration. Now, loosen the distributor hold down JUST enough to allow the distributor to turn. Rotate the distributor counter clockwise until you feel a very noticeable "extra" vibration through the valve cover. It is very pronounced. You will notice it. A blind deaf mute could feel it. Now, back off the distributor slowly clockwise until that extra vibration JUST is gone and lock the distributor down. Drive it. If you don't get any spark knock, leave it there. If you do get spark knock, come back and rotate the distributor clockwise a very small amount at the time until you have no spark knock. Leave the timing light in the toolbox. It just complicates things on a 100% street car.
Hey guys, great stuff. Yes my distributor does have a vac advance. should I keep it plugged off? a little confusing.
Hey guys, great stuff. Yes my distributor does have a vac advance. should I keep it pluged off? a little confusing.
