Front refurbing.
The best plastic glue I have found, 3500 psi tensile strength, glues ABS,
High-Strength Acrylic, Plexus 30500, 1.58 oz. Cartridge made by Devcon,
Mcmaster-Carr has it, You need a gun but I use it for a lot of stuff. It glues all metals, ceramics, concrete, wood, never had a failure with it but JB wont glue metal to plastic It has failed every time, sometimes it holds for 6 months but it eventually falls off.
So mek first, then glue? Or just mek?Fit the plastic pieces together dry, and using an acid brush, dab a bit of methyl ethyl keytone you can get from lowes into the crack. It will suck right in with capillary action right into the joint. It acts as a solvent adhesive and slightly melts the plastic at the glue allowing the original material to re melt and become the glue joint. Let it dry overnight before fooling with it. It requires the pieces to fit tight to work.
