F/A Tech
Hi All, Just putting the 1970 Rally dash back together after fixing the gas gauge ... and trying to see a ground point to the chassis. Is it just the mounting screws ? Thanks
Yes, just the screws; and they're finicky. Always a good idea run a dedicated ground strap/wire.Hi All, Just putting the 1970 Rally dash back together after fixing the gas gauge ... and trying to see a ground point to the chassis. Is it just the mounting screws ? Thanks
Thanks so much, easy to do when it is outYes, just the screws; and they're finicky. Always a good idea run a dedicated ground strap/wire.
Actually, there's a ground wire for the dash frame that runs from the dash on the passenger side to the body just above the passenger side kick panel.Yes, just the screws; and they're finicky. Always a good idea run a dedicated ground strap/wire.
Hi, I don't see a point for it on the instrument cluster.Actually, there's a ground wire for the dash frame that runs from the dash on the passenger side to the body just above the passenger side kick panel.
Its not on the cluster, the cluster bolts to the dash frame . The dash frame is then grounded to the body of the car via a black ground wire on the passenger side of the dash frame that is bolted to the body in the passenger side footwell.Hi, I don't see a point for it on the instrument cluster.
Yes there is.Is there also a ground from dash to steering column?
My car , 1968 Barracuda, has both. Attached to the same point.Brown I think is heater ground. He said black wire.
What year make and model of mopar has this ground wire?Its not on the cluster, the cluster bolts to the dash frame . The dash frame is then grounded to the body of the car via a black ground wire on the passenger side of the dash frame that is bolted to the body in the passenger side footwell.
I found it on my 68 Barracuda Fastback when I disassembled it for a rotisserie restoration. I took every nut, bolt , washer, fastener , clip, wire and plug off the vehicle personally.What year make and model of mopar has this ground wire?
Heres my build thread on here.WOW !! a real labour of love. Have you progressed any further ? Any updated pictures or pictures of completed project. Thanks for the imput
On my '67 its a wire with two ring terminals the other end going to the radio supportscew where it mounts to the dash.
IVR on the Rally panel grounds as shown here
[/URL]
Correct.Mattax, I think the IVR circuitry is located in the fuel gauge in a rallye dash. The lead you are showing is a ground for the noise suppresser.
