you mean the felt things at the top of the door?
I dont want to bend or break it but how does this trim remove?
72ScampTramp,
There is trim possible on the top of the door and at the edge of the quarter windows. These are not part of the cat whiskers at all. They are held in with spring clips, similar to those used on the door panels, but smaller. Slide something like a wide putty knife under it near the end and slide to the end until the knife hits the clip. Pry up gently and work your way to the other end a little at a time. If you try to remove the clip all at once, you will bend the trim. Good luck. L8r
Jim
Ok I got the trim removed. on the to the window sweeps? What is the proper name for these? Know sources for them?
Christ I wish I saw this thread like half an hour ago before I went about trying to get my friggen windows/regulators out.
This is where I ended up with my little chrome pieces... I really hope these aren't expensive
After 10 minutes of careful, careful prying trying my hardest not to bend them I added a little more force and SNAP. Clip broke loose, I bent the sh*t out of my trim and punched myself in the face with some needle nose pliers... and I still can't figure out how to get my windows out. :banghead:
