How Fast is Your Slant (Stock To Boost)
805moparkid
Slant and AFX Guy
Anthem AZ
so guys im curious to see how fast you slant goes at the 1/8 or 1/4...
please post combo and 1/8 and 1/4 miles time!
68 dart 3200lbs
235ci .080 over
10:1 compression
Lots Of Head Work
.475 lift 246 @ .050 cam
super comp headers and clifford intake
600dp holley
904TF with 3500 stall
8.75 with spooled 4.88's
best of 14.25 @ 91.8mph 1.91 60ft/ 8.98 @ 75.4mph (best time was with the car shooting ducks lol)
Stock 170. It doesn't run.
Bone stock 1966 Valiant, 170 cu, 11:26 1/8 mile, 3:23 gear with 14'' wheels three on the tree.
If I had about 7lbs of boost I would be in the eights some where.
By all means not a race car. But some info any anyway
I'll get back to you on that. I'll try it in Spring. Here in IL I use US12 to try 0-60 trials. If I'm the first one to a red light, I floor it and since the speed limit is 55, 60 isn't so bad.
This isn't mine, but it is something to aspire to........ [ame="http://youtu.be/htkLHWLfNKg"]302 Found[/ame]
It's a 62 Valiant, 225, manual,.....all throttle, no bottle.
11.98 @ 110 mph 1/4 mile.
Here is the last 1/4 mile list from .org
***9 Second Zone***
9.85 @ ??? The Drakes, 1938 Simca
9.93 at 132 Charles Myers, Plymouth Arrow, 6/21/2003
9.97 @ ??? Cox Bros, 66 Dart
***10 Second Zone***
10.19 @ 129 Mike Jeffrey and Blaine Mueller's "Buzzin' Half Duzzin' 1968 Valiant
10.5 @ 127 Will 67 Barracuda methonal & nitrous with Cam2 enrichment July 2004
10.74 @ 127.47 - 1.57 60', turbo66valiant, 66 Valiant Signet, 2800# w/o driver, turbo, intercooled, 727, 2.94, AV gas, July '10.
***11 Second Zone***
11.02 @ 120.56 Shaker223, 1.57 60', Turbo/FMIC, 1970 Swinger, 2.76 gear, 255/60/15 radials, 3300lbs Race Wt. Sept 2010
11.363 @ 114.47, Exner Geek, 62 Valaint, 150# lighter than Guzzi, 904, 4.56, Webers, on gas at Cedar Falls, IA 10/16/10
11.436 @ 115.51 mph at A Gas weight, Guzzi Mark 7/16/2011, Samoa Dragstrip
11.500 @ 117.725 MPH (not correct) (NEW B GAS RECORD) Sacramento Guzzi Mark 9-12-2010
11.54 Dave Mueller Alchohol Injected (C/Alcohol Record)
11..65 @ 114.5 Nick Stamm (turboram) 3700# 86 ram turbo NO2 to launch
11.77 @ 116.29 Shaker223, 1.83 60', Stock Slant 6 with turbo, 1970 Swinger, 2.76 gear, 215/75R/14 radials, 3500lbs Oct 2009(retired)
11.88 Ron Hamby at Hamilton Oh. 2004 '66 Dart on NOS
***12 Second Zone***
12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal.
12.02@ 107mph Ron Hamby at ClayCity Ky. 2008 '66 Dart on Alky---
12.33 at 107.88, Samoa, SwinginSixAric
12.43 @ 102 mph at Clay City 10- 10- 09 Ron Parker
12.64 @ 105, Doctor Dodge - 62 Lancer, Sacramento 2010
12.77@104 Andrew Howard,62 Valiant (Mr.Loud) Sacramento, CA.2010
12.941 @ 105.50, Old6rodder (Dick Sappington), HA/GR, "Barn Job #18", ANRA finals '09
12.98 at 101.03 at Redding, "Wayne's World" 170 cu inch (on gas) 62' Valiant -Wayne Erickson-
***13 Second Zone***
13.102@ 99.65 Charlie Schmid, 66 Cuda 170 cid May 23, 2011
13.39@96 sgtmcd42, Crooked 6, red light lifted @ 1000'
13.41@ 96.20 Charrlie Schmid, 66 Valiant 225cid
13.469@ 99.137 PJ Jesiolowski Sacramento Raceway May 2011
13.58 @ 99.46, 1.82 60', 8.63 1/8 mile, Exner Geek, 62 Valiant, Street Driven, 2800#, A833OD 3.73 gas, May 2011
13.74 @ 94.7, Lou Madsen (Dart270), autoX tires, 904, 3.25 rear, 2670 lb racewt - Project V - Clay City Race 10/08/10
13:[email protected] Little Red Piggie- Motor only-RT 66- 8-7-11
***14 Second Zone***
14.061 @ 96.58 Ryan Covalt '72 swinger daily driver 3330# (50 shot) Mason Dixon 7/30/2010
14.15 @ 91.02 Crazy Dart (converted from 1/8mi) 67 Dart,904, 3500 stall, 4.30 gear. 5500 RPM.
14.206 @ 94.76mph 2.05 60' METALSKIN draw thru turbo slant (9psi) AP5 valiant 2.9
14.30 @ 96 MPH Lou Madsen '64 Dart 270 in street/strip trim in 1997 at Pomona Dragway (904w/3400 stall, 14" Radial TAs, 60 over cast pistons)
14.57 @ 94.6 MPH, Lou Madsen '64 Dart 270 in street/roadrace trim, 2009 at Mason-Dixon Dragway (T5 trans, 16" autoX tires, 60 over cast pistons)
14.743 @ 89.81, 1.931 60' Bren67Cuda904, 258 ci Slant (Eileen) 3400 lbs with A/C, Gear Vendors, Full interior including Child car seat, 8 1/4, 3.55
14.79 @ 93.56 Greg Ondayko
14.84 @ 91.22 Ryan Covalt 72 Swinger 3330# Daily Driver/ Mason Dixon May 31,2009 4.30's, 4 sp.OD no nitrous
14.937 @ 91.48 MPH Ceej in the Hooptie, Woodburn 8/13/2011
14.937 @ 89.74 mph "6 Pac To Go" Fopar's Mopar '63 Dart GT/stock convertor Woodburn 8/13/11
14.98 @ 95.29MPH - Turbo'ed '68 Dart street car - Lou Madsen - 2011 Kearney race, 8.5 psi boost max T60-1 turbo, no intercooler or water/meth inj, 3.55 gears, A500 trans w/2200 stall, 3410 racewt, D/Unlimited record.
***15 Second Zone***
15.12 sergio 7/11/9 samoa stock engine 3.91 hedder ,5002 BB converter
15.20 @89 Joel Harris 69 Valiant, 225 stock bottom end, .100 off head, 2bbl, pump gas, mopar268 cam, headers, stall, 3.91, 904, 2750# w/o driver, mostly stock driver
15.34 @ ?? Brian '74 Duster,1971 225 block ,.100 off blk, .100 off head,MP 528" lift cam with 284 duration, 904,4.10
15.39 @ 87.32 Fopar May/4/08 3400lb 53 Ford 225 bored .030 .090 off head custom cam custom headers 904/4.11's
15.39 @ 87.7, Lou Madsen (Dart270) '90 Slantkota with 258" engine, mild cam, 3.23 gear, 2400 stall, 3310 racewt, Clay City Race 10/09/10
15.40 @ 89 mph Lindross, roadster
15.501 @ 88.32, SV162, low comp head, 3.7 diff, May 2008
15.73 @ 88.32, SV162, high comp head, 2.92 diff, Sept 2009
15.6 @ 90 MPH - '68 Dart street car - Lou Madsen - 1996 at LA Cty Raceway
15.82 @ 84.32 1974Duster Kev- Converted from 1/8 mile numbers
15.855 @ 87.25, Rob Simmons, '73 "GodsRods" Duster, 28 May 06 @ SGMP, just under 2,785 #
***16 Second Zone***
16.18 @ 84.26, SV162, low comp head, 2.92 diff, Feb 2009
16.281 @ 82.64 DusterIdiot, Medford, Hpak Duster Holley Annular 600, 3400 lbs
16.35 @ 81.3 70valiant', 3.23
16.59 at 81.68mph TRYSIX '65 Coronet 4dr, Isky cam 228/448
16.707 @ 82.11 Mike Andreas,225 cid block +30. Stock pistons .100 off the deck. Isky 448 lift, 4 speed
16.868, 80.06 MPH J. Skinner '67 Valiant 100 3-speed, stock short block
16.89 @ 78.49 3.23open 75 duster (Wicked/six)
***17 Second Zone***
17.03 @81 MPH. Casey Reed R688 '70 Dart 225/904, 4-BBL, headers. 2.76 open.
17.13 @ 77.30 aaron downing 225, 904, 4-BBL, headers, 390 holley, 3:55 suregrip
17.20 @ 85 The Black Sheep
17.27 @ 79.03 Featherduster76(converted from 1/8mi) 71 Duster 225/904
17.29 @ 78.66 Rhonda Amis '66 Valiant Signet 200 225ci,904 MATS 2009
17.44@78 Slant Cecil '68 Signet 225, 904 ,2975lb w/driver ,140K mile motor with 6x1 header, BBD, electronic ign ,4400rpm shift
17.69 @ 75.78 THOR 65 Dart GT "Madeline"
17.72@77 Nick Bowman 1970 Plymouth Duster 2bbl-904-3.23
17.88 @ 77 Allen Dutra 66 Dart Station Wagon "tow car" 1 bbl 260 stroker w/ 3.23
***18 Second Zone***
18.281 @ 72.99 Mike'68Dart, Sept 10, 2011
18.312 @ 72.31 Vallyant
18.705 @ 73.41 The Hard Way '74 Dart 4 Door 198 Auto
18.832 @ 72.82 Dodgegirl
18.763 @ 72.26 66 Dart GT Convertable, Super six, HEI, 3.23, 904
18.766 @ 70.69 Mike'68Dart, Aug 28, 2009
***19 Second Zone***
19.05 @ 73 Davids63Dart, September 2007
19.21 @ 70 Doc, 65 Dart GT Convertible, stock alm block 225 ,1bbl
Carter, Dutra dual exhaust, 904 auto. trans., 2.94 8 3/4 rearend.
19.26@68 77Volare Wagon, stock, supersix, 833-od
19.35 @ 69.85 THOR, '74 Swinger, Redding Dragstrip (Stock Cast crank-juice engine... stock 2.76:1 "SG") 10/25/08
19.37 @ 69.77 Aggressive Ted, '74 Swinger, Pacific Raceways
19.52 @ 69.26 Slanted66, Altitude 5300 ft (Headers, Isky cam, 1bbl, 904, 3.23s)
19.6 @ 71 eightymopar , 1980 Cordoba
19.78 @69.56 1980volare, 1980 volare,bbd 2.76,28" tires,stock exhaust.
***20 second Zone***
22.18 @ 60.6mph 72polara, '73 /6 Swinger stock and wore out
13.43@98 mph 1/4 mile, N/A, 234ci, 67 Dart, 3.73 gears, 2800+lbs.
63 Valiant 170 stone stock 2.76 gears, maybe take it to Mopars at the Strip to see if it will crack the 19 second sound barrier.....
Love that 66 Valiant !! Warm spot for me as my first car was a 66 170 three on the tree 2 door post..
The slants growing strong on the site,really cool.Alaways liked the little mills.
Is that list for slantsix races only, or for all slant six cars?
My 65 Valiant did 16.01/89mph years ago. 225, Mp268 cam, headers, supersix, 4speed and 2.76 open gears. Hopefully new boosted engine will be quicker :)
805Moparkid, How much was the head cut??
1/8 mile times apply here..
My old rookie title /6 car was running 11.84 on a bone stock mill. I started gutting it even further and added..
*Holley 500 2bbl
*Offy intake
Mopar 6x1 header
My own personal tinkered 904 (free tricks).
3.55 gear..
Lost my job, had to sell the car. Went 11.06 the last time I had it out. Stock head/pistons/block.
*Holley 500 2bbl
*Offy intake
Mopar 6x1 header
3.55 gear..
i think im @ .113 now lol... 44cc chambers
any and all slant sixes
One of mine from a long time ago.
1971 VG Valiant hardtop with a race weight of 3060lb + me@140lb = 3200lb.
Ran it's best ET in 1983 of 14.0@101mph over the 1/4.
Slant 6 bored 156 thou to give 247 inches.
Head was shaved 125 thou,318 valves,lots of port work,std rockers.
Cam was 311deg adv dur,104deg overlap and 0.495" valve lift.
Alloy timing gear with std morse chain.
Carbs were triple 45DCOE sidedraught webers with 36mm chokes,F16 emulsion tubes and 165 main jets.
Headers 1 5/8" primaries into 3.5" collectors.
Electronic dizzy.
4 speed manual.
Rear was 4.0 open centre with 25" tall tyre.
