how hot is hot
iggys68dart
jacksonville fla
here in fla we been getting a little bit warm and today i drove to work my temp gauge was up to 225 degrees i know that isnt great so what can i do to help it [stock 318 and radiator] is a two row radiator that i have flushed and use plenty of coolant any ideas
I live in Arizona and know what you mean about hot weather. A shroud is worth about 15 degrees or so.
What degree stat are you using???
will do its just been so hot like 100 degrees and its tough on these older cars and folks lol i was thinking i might have to go with larger radiator but i will go the five dollar route and see what happens
how hot are you running demon i aint been out your way in a while but i remember 117 degree weather
LOL.....I have a 185 t'stat and it runs 195 or so in traffic. I don't have alot of miles on it yet though. Still a work in progress :)
I need to change the stat in my 350 in my 63 chevy truck.. I had to get a 190 awhile back, advance didn't have any lower when I put the engine in it..
ive had a few of them trucks 64 65 66 67 72 loved them all they got classic lines but hoods tend to rust as well as drip rail on roof but i still enjoyed them had to sell my last one a 66 lwb stepside to pay for my sons operation actually hes my oldest boston terrier but i love him so it had to go so he could stay
My '63 has a '60 model Apachie quad head light grille and hood..
here in fla we been getting a little bit warm and today i drove to work my temp gauge was up to 225 degrees i know that isnt great so what can i do to help it [stock 318 and radiator] is a two row radiator that i have flushed and use plenty of coolant any ideas[/QUOTE
How hot is hot? It depends on your coolin system. I think the formula is for every 1 PSI the system is under, you raise the boilin point 3 degrees....if i remember right. If that's right, then you have a 260 degree boilin point on a 16 LB system, PLUS whatever mixture of coolant you run. Coolant has a higher boiling point to begin with. Remember also, most modern factory electric cooling fans cut on at 230 degrees and that's not a high performance cooling system. Robert Shaw and other companies make radiator caps that go above 20 PSI, so you can really extend that boiling point. You can get it up above 300 degrees, but then you have to start worryin about oil temp. Things you can do. First, does it have A/C? If so, chunk that 2 row core junk and stab in an aluminum 2 row or a stock replacement 3 row. If no A/C then you can have the radiator flow checked. If it cools off going down the road and heats up at idle, the radiator is restricted. Also make sure your clutch fan (if so equipped) is in good shape. If it seems like it lacks resistance, chunk it and go for the Mopar Performance viscous fan package. You have a fan shroud, right? If not, get one. Also, the rubber seal between the hood and radiator support should be there and in good condition. Its purpose is to keep air flowing through the grill into the radiator, instead of over the radiator. If everything is correct and in good condition, there's no reason to add crazy stuff like electric fans and such. Lastly, don't go stickin a 160 degree thermostat in it. that aint gonna help anything unless the old thermostat was bad. I see people doin that crap all the time tryin to solve the problem and it never works. As long as the thermostat opens like it should,it can be a 250 degree and have no effect.
no a/c no clutch fan no rubber strip its been getting warm out there so i was trying to figure out a plan of least cost i believe i know of strip you are speaking of but would you have pic i need to get this thing running cooler as i am sure its gonna cost me a lot more down the road thanks for replys and about fan shroud it came to me with 3 inch aluminum square piece around radiator its homemade but it has gaps between fan and radiator on inside so i dont think it is very efficient
