No mine.
What are the Allen heads on the lifter bores for?
Just saying, but what do I know (nothing). Its a cool engine. If the block is good, that would be the asking price right there, but you never know till its gone through. That block I believe has alot of life left in it if it is good. If I had the cabbage, it would be mine.Till those rods start stretching to the point of fatigue.
If you look at the last two lifter bores at the back of the block(one on each side) they are drilled and tapped at a different angle. My thinking is, after who ever bushed the lifter bores drill through to the oil galley to feed oil to the lifters. Then tapped the outside holes hole and put the set screws in to plug the oil leak to the valley. Could be way off but that was my first thought.
i think the bores are bushed and those are the set screws to lock them in?What are the Allen heads on the lifter bores for?
My thought too.i think the bores are bushed and those are the set screws to lock them in?
My thought too.
My original thought was that the screws were machined on the end to act as keys for roller lifters, but the last hole by the oil pump drive is at an angle and unless the lifter can accommodate that, that theory isn't supported. Looks like a fun motor. I've always wondered about the longevity of aluminum rods, seemed to be a "race only" thing that needed to be looked after closely.I can't see down the lifter bores really well, but it looks like they may be cut for keyed lifters. Set screws to keep them from spinning possibly?
